Page 2 of 7
Goto page: <  1, 2, 3, 4, 5, 6, 7  >
Post new topic
..: Outback :..
No new posts Global Announcement: Règlement général du Forum 0 sub4ever 35,329 Fri 17 Nov 2006 - 15:04
sub4ever View latest post
No new posts   Type de variante ou version pour importation Outback 3.0R ? 2 Luwar 692 Sun 8 Jul 2018 - 13:51
joc02 View latest post
No new posts   Probleme électrique [ Goto pageGoto page: 1, 2, 3, 4 ] 45 toto65 3,663 Sat 7 Jul 2018 - 11:52
patleo View latest post
No new posts Petit soucie au GPL [ Goto pageGoto page: 1, 2, 3 ] 36 kro007 2,864 Tue 26 Jun 2018 - 07:57
cyclodocus View latest post
No new posts   pénurie de pièces ???? 8 sphax12 808 Mon 25 Jun 2018 - 11:32
Godefroy View latest post
No new posts   Amortisseurs - Subaru Outback 3.0R BVA 3 Oxygène 1,468 Sun 24 Jun 2018 - 11:44
toto65 View latest post
No new posts   injecteur gpl hs [ Goto pageGoto page: 1, 2 ] 17 740foué 2,869 Sun 29 Apr 2018 - 22:45
olivier05 View latest post
No new posts   Mâchoires frein à main OB 2001 3 Smaret 856 Sun 29 Apr 2018 - 20:29
Smaret View latest post
No new posts   Toit ouvrant en panne 3 Steph le boul pat 773 Sat 28 Apr 2018 - 16:52
atsem View latest post
No new posts manuel d'atelier outback 2.5 2002 8 eric.2607 965 Tue 24 Apr 2018 - 13:08
subforest72 View latest post
No new posts   Perte des commandes au volant. 9 Steph le boul pat 1,117 Sat 21 Apr 2018 - 21:13
JiPe38 View latest post
No new posts   Usure Convertisseur de couple boite 4EAT [ Goto pageGoto page: 1, 2 ] 19 Tom 3,167 Sat 21 Apr 2018 - 21:03
No new posts Mise sur chandelle d'un outback (avant de faire une cata :-) Points de levages pour cric hydrolique
7 eric.2607 1,218 Sat 7 Apr 2018 - 10:54
eric.2607 View latest post
No new posts   Toit ouvrant 6 malliot 847 Fri 6 Apr 2018 - 10:05
No new posts   modifications outback [ Goto pageGoto page: 1, 2, 3, 4 ] 47 blacklight 3,600 Fri 30 Mar 2018 - 17:56
No new posts   outback bioethanol? [ Goto pageGoto page: 1, 2 ] 24 Olivier 09 3,332 Fri 16 Mar 2018 - 18:45
rc36-51 View latest post
No new posts   Ressort de suspension pour outback 3.0H6 de 2001 références ??
3 jeanbln64 1,188 Wed 28 Feb 2018 - 22:37
jeanbln64 View latest post
No new posts   Démarrage beaucoup moins court fonction de la pompe à carburant.
24 jeanbln64 1,792 Wed 28 Feb 2018 - 22:25
No new posts   Comment démonter console arrière 2007 ? 1 Forestier 856 Sun 18 Feb 2018 - 12:38
Forestier View latest post
No new posts plaquettes avant sur Outback 2013 2.0d CVT changement des plaquettes avant
1 BARTHES 798 Wed 14 Feb 2018 - 08:35
No new posts Outback auto modifié ajout d'un interrupteur pour passer en deux roues motrices
12 sphax12 2,994 Thu 8 Feb 2018 - 11:36
No new posts   estimation outback besoin d'avis compétents poiur une estimation complexe
5 sphax12 2,229 Mon 29 Jan 2018 - 22:26
sphax12 View latest post
No new posts   ripage excessif 13 blacklight 2,161 Tue 23 Jan 2018 - 19:29
No new posts Nettoyants circuit et Injecteurs GPL, les utiliser ou pas??
16 Jean-Louis 1,502 Wed 17 Jan 2018 - 19:10
Jean-Louis View latest post
No new posts   conversion suspension outback => legacy [ Goto pageGoto page: 16, 7, 8 ] 110 parAL1 18,439 Wed 17 Jan 2018 - 10:36
Cyril F7R View latest post
No new posts [Technique] montage attache remorque Witter sur Outback [ Goto pageGoto page: 1, 2, 3, 4 ] 46 cloups 14,569 Fri 5 Jan 2018 - 07:00
pattali View latest post
No new posts   bruit de ferraille sur outback 2.5 GPL de 2005 [ Goto pageGoto page: 1, 2 ] 15 Jean-Louis 1,576 Wed 20 Dec 2017 - 11:04
No new posts   Problème roulement alternateur 7 Zaki 1,485 Wed 13 Dec 2017 - 22:23
Zaki View latest post
No new posts   Fuite liquide de refroidissement 4 Sebdul63 1,052 Tue 12 Dec 2017 - 17:52
No new posts   Questions suite achat OUTBACK 2008 2.0 Diesel 3 lucien 1,001 Tue 5 Dec 2017 - 20:17
Kaprika View latest post
No new posts   Outback ne passe pas au GPL 11 joetjo 1,466 Sat 25 Nov 2017 - 13:05
No new posts   Bruit train avant [ Goto pageGoto page: 1, 2 ] 15 toto65 1,739 Wed 15 Nov 2017 - 12:26
No new posts   Toit ouvrant outback 2006 5 Joduke 911 Mon 13 Nov 2017 - 02:16
Joduke View latest post
This topic is locked: you cannot edit posts or make replies.   quelle jante pour outback 2014 RECHERCHE DE JANTE POUR MONTE HIVERS
1 TALLCB 865 Sun 12 Nov 2017 - 20:40
pez1979 View latest post
No new posts   Recherche d'une Outback 2.5 GPL - importation EU? Risque avec l'import d'un Subaru GPL (drire)
41 jeremyh 3,315 Tue 31 Oct 2017 - 18:12
No new posts BRUIT MOTEUR EJ25 tac tac à froid et en roulant.
18 DUF87 3,371 Sun 29 Oct 2017 - 11:13
No new posts Toit Ouvrant défectueux Toit ouvrant HS
0 pattali 901 Fri 27 Oct 2017 - 10:05
No new posts   Changement d'embrayage + volant moteur 11 drumart 5,037 Fri 27 Oct 2017 - 09:26
No new posts   Ou sont les vis de purges du circuit de refroidissement ? [ Goto pageGoto page: 1, 2 ] 15 Sebdul63 962 Thu 5 Oct 2017 - 05:42
No new posts   utilisation manette LOW 14 blacklight 1,109 Fri 15 Sep 2017 - 10:05
blacklight View latest post
No new posts   démarrage difficile sur outback 2,5 gpl 2006 5 ravetfr 629 Sun 27 Aug 2017 - 11:52
No new posts   remplacement filtre d'habitacle comment remplacer le filtre d'habitacle sur une outback 2.5 de 2005?
1 Elwood87 470 Sun 30 Jul 2017 - 17:23
VChristophe View latest post
No new posts   En vue échange clim suite à galet tendeur cassé Bruit dans le compresseur de clim avant casse galet tendeur.
12 jeanbln64 1,335 Sun 23 Jul 2017 - 15:56
No new posts   Outback 3.0R 2004 - Cosse borne positive sur batterie 1 Oxygène 579 Sun 9 Jul 2017 - 17:04
No new posts   Mecacylation Outback 3.0 [ Goto pageGoto page: 1, 2 ] 19 toto65 1,505 Tue 4 Jul 2017 - 21:26
No new posts   Outback 3.0R 2004 - Saleté de fermeture de hayon 1 Oxygène 582 Tue 4 Jul 2017 - 11:59
Olivier09 View latest post
No new posts   Problème de compression Problème de compression sur 2 cylindres / soupapes
20 Stephan 1,994 Tue 4 Jul 2017 - 11:12
Pierro View latest post
No new posts Outback 2,5i GPL trous à l'accélération check engine [ Goto pageGoto page: 14, 5, 6 ] 78 Denver04 5,268 Mon 3 Jul 2017 - 15:18
No new posts   Silencieux sport pour outback 2001 2 Sebdul63 562 Sat 1 Jul 2017 - 18:01
ArkulA View latest post
No new posts   Horloge/ordi de bord Outback 2005 5 Jean-Louis 811 Thu 29 Jun 2017 - 09:28
No new posts   Kit Parrot Retour d'expérience
9 Olivier09 2,144 Thu 29 Jun 2017 - 06:36
POUG View latest post
Post new topic
