Page 2 of 5
Goto page: <  1, 2, 3, 4, 5  >
Post new topic
..: Châssis :..
No new posts Global Announcement: Règlement général du Forum 0 sub4ever 35,331 Fri 17 Nov 2006 - 15:04
sub4ever View latest post
No new posts Announcement: commande groupée durit "avia" [ Goto pageGoto page: 110, 11, 12 ] 175 parAL1 15,699 Sun 7 Jun 2015 - 09:04
jeanbln64 View latest post
No new posts   Information montage jante en 9.5 9 Swift 877 Fri 1 Sep 2017 - 11:29
Swift View latest post
No new posts Essieu arriere Impreza Break 2007 Les amortisseurs et/ou ressorts arrires de mon Impreza wagon trop souple et trop bas...
3 alamaven 604 Wed 30 Aug 2017 - 11:49
alamaven View latest post
No new posts   Roulements boite vitesse Forester [ Goto pageGoto page: 16, 7, 8 ] 105 Osrod 14,092 Wed 9 Aug 2017 - 16:20
subforest72 View latest post
No new posts   Remplacement rotule de direction 14 fafou 4,243 Wed 2 Aug 2017 - 19:30
No new posts Question bête Boulon de fixation boite/moteur foz ej202
2 em65 577 Wed 2 Aug 2017 - 00:05
em65 View latest post
No new posts   Changement amortos + ressorts sur forester SF5 [ Goto pageGoto page: 1, 2, 3 ] 44 Calou73 7,801 Tue 1 Aug 2017 - 19:01
No new posts   devis embrayage outback [ Goto pageGoto page: 1, 2, 3 ] 35 sdric 2,677 Tue 1 Aug 2017 - 19:00
No new posts   Bruit train arrière WRX 2005 11 xorfel86 4,035 Sat 29 Jul 2017 - 09:37
pez1979 View latest post
No new posts   Tout ce qu'il faut savoir sur l'embrayage hydraulique du SF5 Fonctionnement/Problèmes/Astuce/Purge/Remise à neuf
[ Goto pageGoto page: 1, 2 ]
24 subforest72 15,314 Sun 2 Jul 2017 - 17:58
romromrom View latest post
No new posts   Sifflement dans les virages 9 sub4ever 1,192 Sat 1 Jul 2017 - 17:36
No new posts   Compatibilité jantes 2 Bgt66 703 Wed 28 Jun 2017 - 15:42
Bgt66 View latest post
No new posts   les amélioration du freinage sur Legacy et Outback [ Goto pageGoto page: 112, 13, 14 ] 199 Maskym 32,208 Fri 21 Apr 2017 - 20:07
Godefroy View latest post
No new posts   volant moteur forester 1 MV6 912 Tue 18 Apr 2017 - 22:10
MV6 View latest post
No new posts   géométrie sur wrx break 2001 0 doudziz 617 Mon 3 Apr 2017 - 17:38
doudziz View latest post
No new posts   Pédale de frein molle et qui s'enfonce déboires avec les freins, suite...
11 DarkGrey 2,244 Wed 8 Mar 2017 - 09:36
No new posts   Echappement, quelle marque choisir??? [ Goto pageGoto page: 1, 2 ] 24 dudujura 2,787 Sat 28 Jan 2017 - 13:17
No new posts   Roulement AR 9 Mac Arronii 1,363 Thu 22 Dec 2016 - 22:58
jaguar View latest post
No new posts   Valeurs conseillées pour géométrie SF5 rabaissé ? 12 stevenbauer 1,556 Mon 31 Oct 2016 - 17:34
caterham View latest post
No new posts   Claquement sourd sous caisse Impreza 2008
32 Mac Arronii 3,720 Thu 6 Oct 2016 - 21:29
Mac Arronii View latest post
No new posts   Choix de jantes petit ET pour FOZ SF5 9 fabzilla 1,909 Wed 5 Oct 2016 - 09:53
fabzilla View latest post
No new posts   Bruit frottement lors d'appui sur embrayage Impreza SW 07 2 alamaven 834 Mon 26 Sep 2016 - 22:25
No new posts   Goujons et écrous de roue, conique ou sphérique ? Caractéristiques ? ou acheter ?
9 subforest72 2,990 Thu 22 Sep 2016 - 19:36
No new posts SF5 Turbo qui sautille, rebondit 10 stevenbauer 1,164 Mon 19 Sep 2016 - 18:18
stevenbauer View latest post
No new posts   Avis sur amortisseurs Monroe [ Goto pageGoto page: 1, 2 ] 26 PFSB 5,048 Wed 14 Sep 2016 - 17:33
joetjo View latest post
No new posts   Vidange boite Impreza 2.0 2008 14 Mac Arronii 2,191 Wed 7 Sep 2016 - 13:34
No new posts   silent bloc train roulant 3 olivier22 1,081 Wed 7 Sep 2016 - 12:34
No new posts   Vidange boîte à vitesse Sur Foz SF5
36 Olivier09 5,642 Tue 6 Sep 2016 - 22:28
patleo View latest post
No new posts   Boite GT HS ? 1 Julien68140 701 Tue 26 Jul 2016 - 15:47
sub11 View latest post
No new posts   Info boîte Forester turbo s 9 mimi25 2,654 Sun 17 Jul 2016 - 20:01
r21turbo42 View latest post
No new posts   pb boite impreza gt :( 8 r21turbo42 1,844 Tue 28 Jun 2016 - 18:10
subarouille View latest post
No new posts   Etrier Frein Avant Legacy SW 3.0R disque 316X30 [ Goto pageGoto page: 1, 2 ] 17 VChristophe 1,745 Tue 21 Jun 2016 - 20:35
VChristophe View latest post
No new posts   Vibration rond-point sous la pluie 7 sub4ever 1,351 Wed 15 Jun 2016 - 20:55
No new posts   remplacement embrayage [ Goto pageGoto page: 1, 2, 3, 4 ] 46 oli 18,366 Thu 9 Jun 2016 - 20:17
No new posts   Arbre de transmission qui tremblote Ca vibre !!
5 croustib 1,507 Thu 9 Jun 2016 - 17:10
croustib View latest post
No new posts   Réglage frein a main Inneficace
3 CycloneM2 2,234 Sat 12 Mar 2016 - 20:59
CycloneM2 View latest post
No new posts Pneu Hankook Dynapro M/T RT03 [ Goto pageGoto page: 1, 2, 3, 4 ] 51 subforest72 8,950 Wed 9 Mar 2016 - 15:20
No new posts   Choix pneumatique wrx 9 yanoooou 1,573 Wed 2 Mar 2016 - 07:27
No new posts   problème suspension à air legacy 3 10 gremillet ludovic 1,418 Tue 16 Feb 2016 - 12:47
gremillet ludovic View latest post
No new posts   Ressorts/amortos pour réhausse Forester SF5 : choix des kits 7 fabzilla 1,408 Mon 8 Feb 2016 - 11:53
No new posts   roulement ou cardan grondement en tournant à droite
9 titi34 2,006 Fri 15 Jan 2016 - 13:57
No new posts   [Vocabulaire] Swaybars, Strut Towers, Coilovers.. 6 sml 1,097 Sun 10 Jan 2016 - 13:10
atsem View latest post
No new posts   claquement et a coup gt turbo 2 bincoi junior 775 Mon 14 Dec 2015 - 19:58
No new posts Vous avez quoi comme chaussures de trail ? 5 Niak 1,087 Mon 23 Nov 2015 - 22:54
No new posts   Compatibilité boite EJ22 3 oldschool2l170 975 Wed 18 Nov 2015 - 11:22
oldschool2l170 View latest post
No new posts   Pneus Bridgestone Dueler H/T 684 3 charpito 853 Tue 17 Nov 2015 - 22:13
charpito View latest post
No new posts   roulements ARR fors't 5 varuna 1,129 Tue 22 Sep 2015 - 08:32
No new posts   Bruit boite auto Outback 3.0R 4 MaitreFolace 898 Sun 13 Sep 2015 - 21:01
MaitreFolace View latest post
No new posts   rehausse legacy 12 oliv 2,376 Sun 30 Aug 2015 - 06:04
No new posts   Changement de boîte : raisonnable ? 4 PFSB 966 Mon 17 Aug 2015 - 20:52
PFSB View latest post
No new posts   Usure irrégulière Apres passage au CT
6 Lexus91 1,420 Thu 23 Jul 2015 - 07:41
cyclodocus View latest post
Post new topic
